Турбо за 350z
Valko
Регистриран: 26 сеп 2017, 12:39
Автомобил/Car: 300ZX Z32
Турбо за 350z
Мнениеот Valko » 26 сеп 2017, 12:44
Здравейте колеги!
На скоро се сдобих с 350 z и не ми дава мира мисълта да му сложа турбо. Някой има ли имформация или личен опит с подобен проект?
Благодарил (а): 358 пъти
Изпратили благодарности: 918 пъти
Турбо за 350z
Мнениеот dare__devil » 26 сеп 2017, 13:00
Дано да знаеш английски:
https://g35driver.com/forums/forced-ind ... noobs.html
Valko
Турбо за 350z
Мнениеот Valko » 26 сеп 2017, 13:12
Благодаря! Интересува ме някой захващал ли се е с подобно предизвикателство?
Турбо за 350z
Мнениеот dare__devil » 26 сеп 2017, 13:41
В България не мисля. Щеше да се е чуло :)
Турбо за 350z
Мнениеот tink000 » 27 сеп 2017, 21:16
http://mywikimotors.com/vq35de/
Nissan VQ35DE engine tuning
N/A build
You can use aggressive soft for ECU, it will give about 10 HP, but of course, it is nonsense. To increase the power considerably, you need to purchase performance cams (duration 272/272), valve springs, cam gears, rod bolts, high compression forged pistons, fuel injectors 440 cc, new spark plugs, performance MAF sensor, Kinetix intake manifold, cold air intake, equal length headers, performance exhaust system, Motec ECU (or reflash stock ECU). Upon installing all these aftermarket parts and adjusting ECU, you can gain up to 400 horsepower on the flywheel.
If it is still not enough, you can install individual throttle bodies, more aggressive camshafts, also make port and polish and install big valves. As the result, your VQ35DE will do 8,000-9,000 RPM easily and with no problems. However, it is rather expensive, and it would be more effective to spend this money for turbocharger kit or supercharger kit.
VQ35DE Supercharger
If you wish doing everything for cheap, then purchase VQ35 supercharger kit and install it on your engine. Do not forget to buy block guard also. The maximal pressure on stock internals is about 6 psi (0.4 bar). It is enough to gain 400 WHP. And VQ35HR stock internals may endure about 450 horsepower.
If you want more power, then it is necessary to purchase forged pistons (CR 8.5-8.8), H-beam rods, ARP rod bolts, ARP head studs, Darton sleeves, performance cams (duration 256/256). Upon this you can increase boost pressure and gain 450+ HP.
If to equip such configuration with turbo kit, you will have your own VQ35DET or even VQ35DETT. It will add 500+ horsepower.
Anyway, the most popular and reliable variant is supercharger kit.
Турбо за 350z
Мнениеот tink000 » 27 сеп 2017, 21:22
Мен идеята за компресора ми звучи добре,ако е истина без да пипаш мотора 400 коньие на гумите,навсякъде го дават по лесен инстал от турбото,без нови кюнци,без вода и масло,сила в ниските... :P
ivorec
Град/City: Eлин Пелин
Благодарил (а): 40 пъти
Изпратили благодарности: 78 пъти
Турбо за 350z
Мнениеот ivorec » 28 сеп 2017, 08:48
В Европа му слагат Вортек компресор-но доста скъпо начинание 15,20000 лв.Има и турбо китове от Америка на Греди за същите пари.Всеки сам си решава,но с тези глоби и промени в закона за пътищата,мене лично ме е страх... :idea:
Nissan Almera 2001,1.5,90 hp
Nissan Pulsar 2017,1.6 Turbo,190 hp
Nissan Murano 2005 3.5/235 hp
Турбо за 350z
Мнениеот tink000 » 28 сеп 2017, 12:16
Според зависи кой с колко разполага,ако се ходи някъде да се прави сигурно излиза така,не съм гледал цени ама мисля,че 2-3 бона е компресор(ако се взима нов) и дет се вика ако знаеш какво правиш да му намериш място,да го захванеш,да сложиш оптегач,,да сложиш още 1 ролка на кол.вал,ремъка,не мн.голям кулер,звучи ми като седмица спокойна работа и 3 хилки пък нз...
Турбо за 350z
Мнениеот dare__devil » 28 сеп 2017, 13:22
Дюзи, мап...едва ли е ръг и тръг:)
Турбо за 350z
Мнениеот tink000 » 28 сеп 2017, 14:06
dare__devil написа:Източник на мнението Дюзи, мап...едва ли е ръг и тръг:)
Може би си прав,по запознатите ще кажат,но дори и така да е ми звучи ок ако е мераклия чУека 8)
Върни се в “350 Z”
